Folder download zip file name change
Publié : 27 févr. 2025, 17:03
par jwinney
When downloading a folder of files, the zip file is given the name of the parent folder instead of the name of the selected folder. Can this be corrected?
- example.jpg (127.2 Kio) Consulté 186609 fois
Re: Folder download zip file name change
Publié : 04 mars 2025, 09:58
par farbarch
You will find the right name in the zip-folder.
Publié : 07 mars 2025, 12:31
par jwinney
I would not be asking if this wasn't an issue for us. It adds an additional step to locate the file and rename it before emailing the file to a supplier. It complicates things especially on a mobile device where you don't get the chance to rename the file before it's downloaded. The filename should be the name of the folder you asked to archive rather than the parent folder.
An example:
The parent folder "All Products" contains 50 folders of individual products with drawings and photographs for manufacture. Every time I archive one of the products folders, the zip file is called "All Products" If I didn't rename the zip file to something meaningful the recipient of the file (normally by email) would get very confused, burried under mountain of files with the same name.
Publié : 19 mars 2025, 17:38
The name of the downloaded folder can indeed be problematic, for example in your case. This issue will be resolved with the very next version 25.3.1
Sincerely,
Publié : 25 mars 2025, 18:28
par jwinney
